carver2557
- Jan 23, 2012
- 4
Hi,
looking for a little help if possible. i have a 1989 Carver with twin 470. Had it in this winter to get the out drives rebuit and Helm controls replaced with all the cables from the contols. took it out on the water and the port motor would bog down at 2200 RPM. the gas had been drained while at the shop, cabs rebuilt and compression was tested. Resulkts of this are as follows, Cyl #1-148psi, #2-170psi, #3-150psi and #4-150psi. Aside from the #2 cyl bieng a little high this does not seem bad to me. a leak down has not been at this time. could there be a bad fuel pump on this motor? Could the high compression in the #2 cyl be an indicatror of a bigger proplem?Any insight?
Thanks
Thanks
