Mercruiser 4.3L, running rough under a load
jfrush
I bought a 1994 Chaparral that had the engine replaced last year. I took it out for the first time yesterday. at first it ran fine.It had plenty of power and would cruise at about 47 mph at wot. After a while it started backfiring and losing power. Then it stopped backfiring but it had about half the power it did before.
It still starts right up and runs great until you put it in gear. It takes forever to plane out and it's top speed has dropped to about 35 mph.
I had my friend who is a car mechanic with me and we tried adjusting the air/fuel mixture but that didn't make any difference.
I feel like it's an ignition problem, possibly the coil. The problem is that it runs fine when not under a load so I won't know if I fixed the problem until I get to the lake again wich is over an hour away.
RL Gman
Re: Mercruiser 4.3L, running rough under a load
I would start simple. Possibly bad gas? How long has it been in the tank? Then fuel filter and water seperator...
180shabah
Tell your friend to stop touching things - the carb DID NOT just suddenly go "out of tune" running accross the water.
This is a new to you boat, so you have no history. Now is a good time to look at a FULL tune up, filter and fluid changes and some systematic troubleshooting not just twisting screws to see if it gets fixed. If you suspect the coil, get a meter and check it.
There are some great DIY lists in the adults only section as well as downloadable factory service manuals - you NEED these, no clymers or sealoc.
chargerboy
Check your compression of your cylinders too, you might have blown a piston.
Bt Doctur
a water fouled spark plug from a leaky riser?
Ayuh,...I agree with Shabah,... Diagnosing is better than Guessin'...
The current Problem sounds like dirty Fuel Filters,+ generally Crap in the fuel...
