Mercruiser 4.3L Audio Warning
Status
Not open for further replies.
soleil
New to the forum but there is lots of good information here.
Need some help. My audio warning comes on intermittently. Oil pressure fine and right where it should be. Temp in the green at about 170 degrees. Drive lube also fine. The boat and motor are 2005 model year.
Is there something I am missing? Not only is it loud,it scares the heck out of me when it comes on.
tommays
Re: Mercruiser 4.3L Audio Warning
You have a temp switch ,oil pressure switch and a oil level switch in the drive lube tank
Any of them sound the same alarm So yo can locate them and dissconect them one at a time to find out which one is giveing the alarm and then repiar the problem
Tommays
soleil
tommays:
That makes sense. Thanks. The Merc manual says that the drive lube alarm will be on/off where the other two are continuous. The noise I get is continuous, so I will try the oil& temp test first.
newport dave
Yes, the oil pressure, coolant temp, and drive oil are the first things to check.
But with a ECM555 system, there are a lot of other things that can set an Active Fault Code(s), and alarm. The best thing to do would be to have someone with a scan tool connect up to the engine and check it out.
Dave
Don S
Is this an MPI engine or a carbed engine. A carbed engine isn't going to have different alarms like an MPI.
Did you look in your owners manual? There is usally a discription of the different alarm sounds there.
What is the SN of your engine, that could help ID your exact engine.
soleil
Carb engine.
Checked manual first off (because I am new at this, I have it on the boat at all times) and it states that the AWS will sound continuously if oil pressure too low or temp too high, and intermittently if stern drive oil level too low.
Mine goes continuously but not all the time. Boat will run fine for awhile and then next time I start the boat up it goes off. I shut it down right away and re-checked everything. Start the boat and it goes off again, but if I put it in gear it stops. Next time I start it, no sound at all. Could be a short in the sytem, I guess. I think I will have it checked by the marina as it is still under warranty.
Lazy Susan
Carb engine.
So what did you find out? I have the same problem with an 07 5.0.
JEAN PIERRE
Hi Igot a same engine as you and the same audio warning, didi you find the problem at last?
thanks to help me
JP
JEAN PIERRE
Hello Soleil,
i got the same engine and the same audio warning without any reason! did you find something at last?
thanks by advance if you can help me.
JP
Status
