I recently bought a 1993 23 ft Searay Cruiser with a 4.3L Mercruiser. The engine/boat only has 378 hours on it. When I had it summerized the dealer tuned it up, replaced several out drive seals and the alternator. I took it out on the maiden voyage today and the engine sputtered alot around 1500 RPM and would not get over 2600 RPM underway, even though it ran smooth at that RPM. While in nuetral te RPM's will easily get up to between 5000 and 6000. Granted this isnt a real big engine for this size boat, but it should go faster than approx. 10 mph. I said approximately because the speedometer wasn't working either. This is a beautiful boat in great shape, but I have already spent a bunch of money.
I would appreciate any suggestions of things to check for the slow speed/RPM or speedometer problems.
I searched old posts for the speedometer problem and thanks to a post by BAYLINER185 I have resolved the speedometer problem. The shop had left the small black pressure tube disconnected just above the cavitation plate on the outdrive. I re-connected and blew canned air through the speedo hole, AND IT WORKS! Thanks BAYLINER185
