Mercruiser 4.3 starts only when a DMM is connected on the battery poles
Mattias-Sweden
I have a strange issue with my Mercruiser 4.3 2006 mounted in a Utter C66 Exclusive.
The power trim will not work neither will the instrument/engine start when I put the ignition key in run.
If I attach a DMM to + and - directly on the battery, everything works, power trim and the engine starts. I have actually tried two different DMM and both on/off with the same behavior. The batteries are OK, and i have also tried with different batteries.
I have checked the terminals that I can find.
I have a techmate pro and checked the faults and there are non.
Please help me in finding the root cause.
BR
Mattias
Ayuh,...... Welcome Aboard,....... Have you removed the cables, 'n cleaned everything to shiny Clean metal, 'n reattached 'em yet,..??..??
Mattias-Sweden
I have now removed every cable joint that I found in the boat/on the batteries/on the "dashboard" Cleaned the surfaces and re-attached. It works now. I think I was a bit tricked by the strange behavior with the DMM.
Thank´s!
now seal the connections with marine electrical varnish (available at most battery and marine stores)
