Mercruiser 4.3 stalls at full throttle
mkfs9
Back from holiday skiing and cruising around. then on the last day decided to open her up and she just seemed to be starved of fuel at wide open backed off and it picked up. Runs perfect the rest of the time , have owned this 1988 boat from new and never had any think like this before. Any help would be great thanx
mkfs9
Re: Mercruiser 4.3 stalls at full throttle
Must add just had lower shift cable replaced, wonder if its the micro switch cutting in because it does not splutter just seemed to cut out at full throttle, Mmm
spdracr39
Change your water sep filter and fuel filters. Also you could check the fuel pickup screen in the tank for any blockage. Doesn't take much to starve for fuel at WOT. If all that checks out it might be the float is set to low running the carb out of fuel.
mkfs9
Thanx for that. I have no fuel/water filter but did check the one on the carb and it looked perfect. coulg be the the float then its never been adjusted ever to my knolledge. as said runs perfect except that last 10% of throttle.
ktbarrentine
Agree on the possibility of the float.... While your checking that, how about a full carb dip and rebuild? How long since its been done on this 88? How many engine hours? I love carb rebuilds... kinda therapeutic. And if really needed and done right, the results are tremendous.
generator12
I would tee a pressure gauge off the fuel pump to see if you're maintaining normal pressure. If so, look into the carb. If not, look upstream of the gauge. (Fuel filter, pump, fuel tank vent, etc.)
Helps eliminate the guesswork.
