Hi All
I have a 1992 Mercruiser 4.3 V6 Thunderbolt IV ignition 2BBL Mercarb. Location: South Pacific
Boat: Bayliner 2052 Cuddy
Ok so before I start pulling the engine apart I thought I see what the experts have to say.
After the winter I put the boat back in the water it hadn't been run for 6 months.
I notice at full throttle I was only get 2800rpm and moving very slow. It all sounded good but felt like it was running on 4 cylinders. I also noticed it didn?t want to idle and would pop and back fire through the carby when shifting between forward and reverse.
I have fresh fuel, replaced the Fuel/Water separator and no water in old one.
Fuel pump is working well and carby appears to be working well, choke open and good flow of fuel from jets.
I have replaced the spark plugs, distributer cap, rotor and leads.
When I pulled the plugs I think I found a clue.
4 of the plugs are dry and light brown/black and look good, but when I pulled cylinder 4 & 6 the plugs where clean and wet with what looked like oil, it may have been water mixed with oil but was tick and brown like engine oil.
After this a did a compression test and all cylinders came up good around 150-170psi although both 4 & 6 came up at 185psi which makes me think once again oil.
So this is where I am at now, my guess is either Head Gasket, Intake gasket or exhaust gasket. I know that cylinder 4 & 6 have side by side exhaust ports but the intake ports are separated.
So as I said I would like to hear from the experts before I pull off the head.
Thanks
Thanks
