Scrowley707
- May 20, 2013
- 20
Hi folks I am new to I/O but have mostly had wakeboard ski boats. So I just bought this 1996 18.2 Regal with a 4.3 LX alpha gen + outdrive. I took it out for the first time and it was running very smooth for an hour then I felt it loose power for a second. I slowed down and everything felt ok so I started to go again and when I got to 75% it just died and wouldn't start back up again. The coil tests good. I unplugged the tach. I bypassed the shift interrupter. I went through the 5 step ignition test that. I do dot get spark from the green white wire from the distributor when I put a spark gap tester between the coil and ground. Does this mean I need to change the ignition module? My ignition module is 807829-1. I took it off inspected it. It looks good put it back in and same result.
