BigFuzzyBush
Thread starter- Joined
- Jun 23, 2015
- 4
I have a 1998 180 Sea Ray Bow Rider with a Mercruiser 3.0 and a Alpha One Out drive. Recently had to replace the starter so I decided to change the plugs and wires along the way. Rookie mistake I made was not paying attention to wear the wires went on the distributor cap. I followed the firing order instructions from another posting but I'm guessing the firing was out of order when attempted. Motor turned a few times then sounded like it got real tight which then took out my starter. Got a new starter (haven't reinstalled it yet), now I'm trying to find TDC so that I can get the firing order right. However, I can't seem to rotate the engine manually (unless I'm doing it wrong). I can turn the alternator but none of the belts seem to turn, just the pulleys. The the crankshaft pulley is not turning, just belts moving. Is there a chance I seized up the engine or am I completely overthinking this and just doing it all wrong? Any help youfolks can provide would be greatly appreciated. Thank you!
