ImperialV184
Thread starter- Joined
- Aug 4, 2011
- 99
Hello,i am rebuilding a mercruiser 165 3.7 liter, and i am trying to bolt on the starter motor. Got a new one since the old one was rusted out. the manual calls for 60 foot pounds of torque to secure the starter......... but when i did this i broke off the bolt. the set up is confusing. The block has .5 in threads but the bolts that i removed were 3/8 x 4.5 long not using the threaded block at all. I got new class 5 bolts and went to attach new starter and the bolt broke at about 50 foot pounds, i had to use a wrench to hold the nut while i used the torque wrench on the bolt (not ideal but i could not verify torque on the nut do to clearance or lack of the right tool) When i try to buy part the schematic seams to show a fully threaded bolt going through the block with a nut on the end but the description says it is 3/8 x 4.5 which is what i removed. so confused and bummed because i am so far into this rebuild. I have read all the horror stories on this engine and have addressed all the pitfalls heat exchanger, stator replacement, cam shaft leak....etc hope i can figure this out and get this thing working, thanks for the help.
