Mercruiser 3.7....no fire
Wayne in MO
Started up all day long on Thursday, now won't fire. Electronic ignition, put on new coil, checked plug wires, plugs, distributor cap and rotor.....still no fire. Any suggestions?
Don S
Re: Mercruiser 3.7....no fire
Kill switch have the lanyard installed? Do you have power to the + terminal of the coil with the key in the run position? Could be a coil, have you checked the coil with an ohm meter? It may also be the electronic conversion. No way of testing those things.
Wayne in MO
Installed two different coils, still no fire. Will not fire with points either.
Don S
did you check the voltage too the coil while cranking?
Don S
No, haven't done that.
Well, you better go do it. You won't know what to fix until you do.
Meter on VDC, black lead on good clean unpainted ground, red lead on the + terminal of the coil. Crank the engine over and see what the voltage is while cranking.
