franktank11
Thread starter- Joined
- May 26, 2011
- 21
i am in need of some help.....i have a project boat 3.7 mercruiser 470 that is still over heating....work performed: i have replaced the head gasket and resurfaced the head, carb rebuilt, starter, fuel pump, plugs and tune up.
here is whats happening. last night i put the carb back on and fired back up (Sounded Great for lots of hard work i was happy
) and ran for a 15 mins then started to over heat at an idle so i thought i was low on coolant so i went this afternoon and picked up coolant and mixed it with water and started it back up. which leads me to my first question how much coolant should i put? fill till i see some in the resivor? i put coolant in and saw that coolant was starting to come out from where the muffs are located. not good i assume :facepalm:
so i started it and ran for 20 mins and started to overheat agian. the first 5 mins no white smoke, after 10 mins lots of white smoke, the last 5 mins some white smoke not as much though.
i have done some looking around and this leads me to believe there is something wrong with my lower unit? maybe
thanks in advance for your help
