Hello,
I have a 2000 bayliner capri 1750 with a mercruiser 3.0l 135hp engine. I recently had is serviced for a slow leak in the outdrive oil. As part of the service they pulled the drive and replace a couple of seals in the upper unit. The alternator belt was also replaced. Today was te first time in the water after the repair and the bot is running fine however it seems like the RPM's re much higher than normal. I am getting over 4K at 2/3 throttle. Did something not get put back on right? the prop is original and hasnt been changed or modified.
thanks Chris
thanks Chris
