DogCompany
- May 12, 2013
- 11
Re: Mercruiser 3.0L/LX Alpha One - Gear Lube Hose Leak
Procedural video:GIMBEL RING DISASSEMBLE - YouTube
You may have to remove the hinge pins and pull the bell-housing back slightly. To access the hinge pines, turn the steering about half way in one direction to expose one of the trim senders. Remove the 2 screws holding the sender on, then remove the big steel hinge pin. Turn the steering the other way (being careful not to trap the loose trim sender) and remove the other sender and hinge pin.... Be careful, as there are milar washers on the inside of the gimbal ring, next to the bell-housing... They have a habit of falling out very silently and you don't even know they're gone... Not good when you come to re-assemble...
Chris.......
