I replaced the Impeller kit with Housing and oil seal, now the water circulation are coming from muffler and not from the upper unit as before. what I did wrong?start with the impeller
Apparently you installed an auto exhaust with a muffler...not sure where you're talking about the water exiting.I replaced the Impeller kit with Housing and oil seal, now the water circulation are coming from muffler and not from the upper unit as before. what I did wrong?
Would guess from the overheat the flapper was melted/destroyed and the pieces have fallen to the bottom of the exhaust pipe and are blocking the idle relief port..water circulation is coming out from exhaust (Propeller) and not from the upper unit
