Re: Mercruiser 3.0 takes long time to start...
Don S - Can I do this without trying to start the boat? Im not near a lake right now.
Don't you know how to run your engine on muffs (aka a flusher)?
I am beginning to think the only problem is your starting method. Especially if you have never operated an engine with a carb before.
They DO NOT start like your EFI car. It takes a bit of getting used to.
You start by putting your shifter into the throttle only mode, then pump the throttle to full throttle at least one time. Do not pull it all the way back to neutral, or you will have to put it into throttle only mode again.
Once you pump the throttle once or twice (time and trial and error will tell which is best) put the lever at 1/4 to 1/2 throttle and crank the engine. Don't let it over-rev, pull it back as needed to keep the rpm around 1200 to 1500 rpm until it warms up enough to idle on its own.
