hillsideman
Thread starter- Joined
- Jun 16, 2008
- 8
Last season (2010) I purchased the boat of my wife?s dreams, a 2002 Bayliner 185 with a Mercruiser 3.0 litre 4 cylinder in-line engine. Since that time I have been struggling with 2 problems. 1.) The engine will not idle until warm. I have to pump the throttle to keep the engine from stalling until it warms up. 2.) The engine often stalls when throttle is applied from a low forward speed or from neutral. This makes for interesting situations when exiting my slip at the marina in breezy conditions. With mid to full throttle the engine runs fine.
So far, I have tried gas additive (Seafoam), carb cleaner (Deep Creep), a new fuel filter, and new plugs. A local marine mechanic, who was recommended, said he found no problems when he put the boat in his tank. I can?t give you rpm info because the tach is unserviceable on this little gem.
I could learn to love this boat if it didn?t give me ulcers during low speed maneuvering. I have browsed the forum and haven't found a problem close enough to mine. There is so much information out there, I don't know where to start. Any suggestions would be appreciated !!!!
