briggs09hp
Thread starter- Joined
- Jul 20, 2009
- 24
Hello,
I am currently looking to buy my first boat. I do not know much about boats, but I am learning. I do know quite alot about automotive though. The boat I am looking at has a 1989 Mercruiser 3.0L 4 cylinder. The engine runs good, and I have driven the boat a few times. However, the owner was honest with me and told me that the stater is intermittent. He took it to his mechanic for a starter replacement, however the mechanic found that one of the mounting bolts that hold the starter to the block is snapped. I looked at this today. There are two bolts, a long one and a short one. The short one (outer bolt) has snapped about a 1/4 of and inch within the block (none of the bolt is protruding from the block) I have included a picture. It does not look corroded at all.
The owner is willing to cut me a deal because of this problem. When i was looking at the boat, i noticed that there was a small angle bracket that was removed when the old starter was removed.
I am wondering if someone can post a pic, or show me a picture of their starter and how it is mounted. Is there an angle bracket that holds the starter on? I really do not want to pull the engine and go through the hassle of removing that broken bolt, so i am thinking i can just get a grade 8 bolt for the bolt that is still good, and use this angle bracket, and i think the starter should be ok. I mean, it has probablly been like this for a long time. There are no abnormal noises duuring starting and i dont see any flywheel damage.
I would hate to let this boat go because of a broken bolt. And i can only imagine what a mechanic would charge to pull a motor. It is in very nice shape, and a good starter boat for me.
What do you think? Thanks for any help,
Matt
Matt
