Mercruiser 3.0 in regal 1800 - Temp gauge problem
The gauge on the boat is reading 190f I have changed the the sender unit, thermostat, exhaust manifold and recently done the head gasket and changed the temperature gauge itself and it still says the engine is overheating. When using a IR thermometer next to the sender unit is says the engine is 160f . is there something in the wiring loom giving the false reading??
Any help would be great !!
thanks
Jon
Re: Mercruiser 3.0 in regal 1800 - Temp gauge problem
Ayuh,... What about the Impeller,..??
yep I changed that as well ! is there an iline resistor in the wire from the sender to the gauge?
tschmidty
The temp gauge is based on resistance. So get an ohmeter, check the resistance at the sending unit (between the terminal and ground) and then check that same resistance at the gauge. My guess is a bad ground somewhere at the gauge side of things.
When measuring sender resistance the sender wire must be disconnected. An incorrect sender will cause an erroneous gauge reading. The gauge and the sender must be compatable. There is no resistor in the sender wire between the sender and gauge. If ground was missing the gauge would not work.
