Re: mercruiser 3.0 backfiring and running bad
Just my 2 cents , You say to adjust the idle mixture , I did it like the service manual says, but my question is what does it have to do the idle mixture with the top end running conditions??The boat idles fine is the 2300rpm up that is causing the problem and I checked the advance and it advances like it should be .
Just asking??
Thanks
And again like I said the boat runs perfect even top end for a few trips up and down the river, if I stop it then it goes downhill. So that's what drives me nuts, how come you run perfect now and after a stop that's it???
If there was an adjustment or anything else it would not run since the start !!!
Just asking??
Thanks
