Okay guys.. need a little help with my prop. I just purchased a 95 searay 175 . Took it out a few weeks ago to make sure it was working correctly. My WOT was at 4000 rpms but from the reading I've done it should be closer to 4600. I just checked my prop (which is pretty beat up) and read the numbers.. it's a stiletto m1419 which is a ss 14 1/4 with a 19 pitch 3 blade. My top speed was at 29 mph via gps. Is this normal for this prop and my motor or am I loosing top end speed somewhere? I've contacted my local marine shop to see about refurbishing my current prop which will run between 150 to 250 range. My question is how do I get the most out of my motor.. the boat will see mostly pulling a tube with kids/adults. I've read about people going 4 blade which will improve top end and hole shot... is this correct? What recommendations would you give on switching to different prop which will put me in the optimal rpm range for my motor.
