I have an 86 Wellcraft with a Mercruiser 224cid 170 HP engine. Wont start this spring. Replaced cap, rotor, plugs, and completely rebuilt carb inclusing new fuel filter and accelerator pump strainer. Pressing accelerator produces a good stream of gas into the carb. When I open the fuel fitting going into the carb I get a spray of fuel which tells me its getting fuel to the carb. It has spark and will start briefly on starter fluid so I presume its a fuel problem not electrical. Its as if its not getting enough fuel to start unless I use starter fluid or pump the accelerator. Then it starts briefly and chokes out. Could it be the fuel pump is working good enough to produce some pressure but its too low of pressure? Im at a loss here. The carb was really dirty when I went through it and required alot of cleaning. Now its like the Im not getting fuel out of the primary jets, only from the accelerator pump. HELP !!!
