Mercruiser 165 Won't Crank.
TruDaddy
Hello All,
I have been using this forum and the invaluable amounts of intel that it provides but have yet to post. I purchased a late 60's early 70's Mark Twain V Sonic Tri Hull with a Mercruiser 160 hp I6 motor but I simply call it the 165 because it is basically the same.
I bought this bad boy for $350 because the working parts and trailer were worth more than that. So here is what I am currently dealing with. Last year I had the gimbal bearing and boots replaced. Prior to doing that I had the mechanics "run" the motor to see if it fired up and would run to give an opinion of whether the engine was worth putting work into. They said they started it and I went ahead with the repair. Fast forward to this year.
I pulled off the cover and begun to hook up my new fuel system. Since I purchsed this boat I have rebuilt the carb twice. Ethanol gotta love it. So I pulled the tanks gave them a bath inside and out had them tested for viability as tanks. They are good to go. I then put in new lines and added an inline fuel water seperator. I did not fire this bad boy up last year because I needed a flexible fuel fill hose to connect the inlet s to the tanks. The offset was to great for standard fuel fill. I got it over the winter and put everything back together. I hooked up the battery and water and turned the key...CLICK. No turning of the motor. The motor was not turning just the click.
I have the shop manual. I got out the test light and checked the slave solenoid. I thought that it tested bad so I bought a new one. Put it in and got the same thing...Click. I also got the same results on the light. According to the guide I used from this site it said it was wrong. I might have done something wrong let me know:
  1. held light to left terminal with yellow/red wires - glowed with no crank went out with crank
  2. far right terminal held light to the nut and nothing with or without crank
  3. tried the other two terminals and got nothing.
According to what I thought this meant the solenoid was done.
Next I moved to the starter. I pulled it and bench tested it. It works great. Pops out and spins with no proplem.
Now I am dreaded that the motor is seized. I tried pb blaster in the spark plug holes for a couple of hours andd nothing changed. Three plugs had significant rust. So:
  1. pulled the exhaust/intake manifold (some rust in the ports)
  2. pulled the cylinder head
  3. pulled the rods first and they are straight and look solid.
  4. The valves and head is a different story.
Valves are cruded up with years of carbon and aren't seated that well. Also there is some rust. The cylinders 5 and 6 did have some rust on them. I used some 150 grit and worked it off and then used 1500 grit on the inside of cylinders for polish. I did not put a guage on them but cylinders appear to be okay. Piston head are actually not bad. A little surface rust and difinately rust along walls near rings. I have been soaking the cylinders in PB blaster and Mystery Marvel oil.
As far as the head and manifolds, I did an electrolysis bath. That is an awesome process that has worked wonders. I highly recommend that. I have yet to find any cracks in the manifold or head. I did find a crack in the block over the water jacket.
Before everyone sighs and says junk it and start fresh, that isn't happening I need suggestions based upon current discovery and willingness to do the best with JB Weld or similar. I have drilled out the crack, dremmelled it and cleaned the hell out of it. JB Weld can work depending upon expectations. With that being said, I have yet to try and crank this motor since I have taken apart. I don't want to take this motor out just yet. Breaker bar? The pulley is behing motor mounts. Is there enough room to wiggle the crank. Also I drained the oil and there was about a quart of water that came out then oil. Is it possible for the crank to seize? How likely? Afterall water is heavier than oil and sits on the bottom of pan. Crank theoretically should have been in a poor quality oil. Should have protected enough for sitting.??? I will post more pics soon. Apologize for the length but trying to be thorough. Also should I pull the outdrive b4 trying to turn engine? If the engine will work and the outdrive will work I will move to the interior restore next. Please help folks. Again I know a new engine/boat would be better but that is not productive. I want to take this as far as I can. And I can take things very far on my own.IMAG0111.jpgIMAG0112.jpg
Don S
Re: Mercruiser 165 Won't Crank.
Sorry, I got bored reading your novel, what exactly is your question? If this is it, " I hooked up the battery and water and turned the key...CLICK. No turning of the motor. The motor was not turning just the click." then go to the link below and follow the troubleshooting steps.
http://forums.iboats.com/showthread.php?t=167035
Fordiesel69
+1
Get out your meter and figure it out. Jumper around the starter solenoid and see if the bendix enguages. From there the starter will turn if it is good.
dubs283
boy...you guys didn't get to the part where he pulled the head and found valve seats junked, and all the rust in the cylinders, and water in the oil pan, and...
sorry dude, it sounds as if your engine may be junk - yeah, you can jb weld the one crack you found, but what if there is a crack elsewhere that you can't see, or you fix it and the jb weld fails and you have to disassemble the engine to repair it (again)??
best bet is to find a rotten boat for donor parts, i.e.- long block that is sound and go from there, you may be able to sell the drive to offset your other costs
TruDaddy
I realize I wrote a monster of a thread but was trying to be thorough. Apparently that is too much for the attention spans of some.
So here is a question, what is the chance the outdrive is keeping the motor from turning?
As far as finding a solid used block, I have looked. There are not any good affordable ones around right now. And $1500 - $1900 new/rebuilt is not an option.
Ayuh,... Anything is Possible...
Pull the drive, 'n Try it...
Even in neutral,..
Everything but the propshaft turns With the motor...
