Mercruiser 165 water pump
mike2011
I have a Mercruiser 165. I have a leak coming from a factory hole behind the impeller. The screw that attaches the impeller is stripped. I am having trouble getting it off to replace the seals. Anybody have any ideas of how to get the impeller off with the stripped screw?
Bt Doctur
Re: Mercruiser 165 water pump
Merc 165 WHAT? 3.7L circulating impeller, or impeller in the drive
Don S
That narrows it down to 2 engines, is yours the 4 or 6 cyl version of the 165?
Which impeller are we talking about? The one on the engine or the one in the drive?
mike2011
It is a 4 cyl. It is the impeller that is in the engine not the foot.
stonyloam
If you have the stud attachment, most likely you are turning it the wrong way. I believe you have to turn the impeller clockwise to remove it.
Found this: "More recent models had a "nut-shape" cast into the impellar and the entire impellar threaded onto the end of the camshaft (spins to right to remove)".
achris
More fish than mountain goat
Oh, it has an impeller in the drive ('foot') too... Just to make life that bit more interesting... :D
mike2011
The problem is that the screw in the middle of it is stripped so i have no way of being able to hold that screw in place to remove the impeller or to take the screw out and then get the impeller off. Is there good way that i should go about getting it off or will i end up having to just cut the nut off and the screw in order to get the impeller off
stonyloam
If you have the impeller with the "nut shape", I believe you can hold the stud it with a Allen wrench inserted in the end. I am not sure what is stripped. Does the impeller spin on the stud, or does the stud turn in the cam? If the impeller turns on the stud, you may be able to unscrew the stud using an allen wrench. May need some heat as it could have been installed with locktite. Not exactly sure which way the stud turns to come out, you can check with your local Mercruiser dealer, sounds like you will need a new impeller anyway.
mike2011
Yes it is the allen wrench screw that is stripped out. We tried to put heat on it and that still is not working.
stonyloam
Sorry I am so thick LOL. So when you turn the impeller (with a wrench on the molded "nut" ) to the right (clockwise) the stud turns too?
stonyloam
That is not good! You could try inserting an Allen wrench into the stud and holding it firmly in place and then turn the impeller to the right to see if you can remove the impeller from the stud. Someone may have used locktite on the impeller threads, so heat may help. If that does not work, you could try some vicegrips on the impeller, pulling outward as you turn it to the left. I am not absolutely sure but I think the stud unscrews from the cam by turning it to the left. Sounds like the stud threads stripped out in the end of the cam when you tried to remove the impeller. good luck.
