I recently bought a boat that has a Mercruiser 140, 4 cylinder engine in it. When I test drove it, it would hesitate on acceleration. As long as you eased into it, it ran fan, but accelerate to fast and it would bog. I bought it from a guy who is the service manager at a big boat shop. He is not a mechanic, however, his mechanic told him it needed a carb kit. When I bought it, he handed a rebuild kit from mercruiser for it. I have taken the boat out twice, once with Seafoam, and it still runs this way so I decided to do the rebuild. I have done rebuilds before on carbs with no trouble, however, when I opened up this carb, it looked to be clean as a whistle. Still, since I had gone this far, I said I would do it anyway, could be a leaking gasket or needle. Well I have it totally disassembled and started comparing new parts to old. All is the same except there are two little ball bearings that are not exactly the same size as the old ones. Is this a problem? Also, I have a brass rod that is about 3/8" long and 1/8" wide with straight sides no button head or anything. It came in the bag marked as 31-744 07E5 that contained the needle valve for the float, the spring for the valve, along with the small shaft with the button head and some sort of jet looking part. This brass shaft fit into the jet looking deal nicely, however mine did not have that when I pulled it out. It doesn't go with the needle valve as the other shaft goes with it. Does anyone have an assembly diagram for this carb, or can anyone tell me where this part goes?
Thanks in Advance!
Thanks in Advance!
