mercruiser 120 exhaust riser question
kjmacke
The engine temp seems to be normal at 160 degrees. The guage never varies at all. The possible problem is the bottom of my exhaust riser is cool to touch gets pretty hot at the top of the riser then cools off again at the bottom before it exits through the bellows. Is this normal or do I have a clogged up riser??? Thanks Kellyriser.jpg
Bt Doctur
Re: mercruiser 120 exhaust riser question
depending on where you run(sand ,silt, mud,etc) riser life can be 3-5 years.how old is this one?
kjmacke
Any other thoughts about riser temp. click on the picture to see what I mean. Thanks for any input.
