Mercruiser 120 cooling question........ any help appreciated please
libellav15
Hi all
has anybody got any tips on how to confirm the water cooling system is working efficiently please? 1972 Mercruiser 120 with pre-alpha leg.
i know it sounds like a dumb question - but i would love to be able to visually/physically check i have a good flow (raw water cooling system) - and the exhaust water outlet is always below the water (obviously:D).
i guess i could run it with the muffs on out of the water - but its a riverside mooring and getting it to a slipway is a big job.
any tips/tricks/advice would be appreciated
the reason i ask is the temp guage climbs nicely to the middle and sits there - so i have never questioned it - but then just after a fairly gentle half hour run this afternoon i leaned into the engine bay to loosen and adjust the distibutor and put my hand on the riser - its quite hot - is that normal?
and then i have suddenly realised that i am trusting a 1972 temperature gauge with the entire wellbeing of my engines internals!
No hot rubber smells, no hot smells to speak of - just would like to have a visual that the flow is good
cheers guys
adam
Blk-n-Blu
Master Chief Petty Officer
Re: Mercruiser 120 cooling question........ any help appreciated please
If you locate the hose that brings water from the outdrive into the thermostat housing you can do a bucket test. See how much water is moved into the bucket in 30 seconds x 2 = GPM gallons per min.
libellav15
cheers for that
any idea what GPM i should be getting at (neutral) idle of 900 please buddy
cr2k
You can also splice in a short piece of clear vinyl hose to that hose and see the flow.
myoldboat2
> 1972 Mercruiser 120 with pre-alpha leg; (neutral) idle of 900
I don't have the specs in front of me, but 900 rpm neutral idle sounds high to me. My 1974 Merc 140 spec is 500-600 rpm idle in forward gear; mine does that and idles in neutral not much higher. Too high of an idle speed can damage the shift dogs in the lower unit.
As to the water, the inlet hose connects to the back of the water distribution block (the casting the thermostat sits in), right on top of the front of the engine.
For comparison, my 140 warms up to about 135 degF and when run hard stays around 150 to 155 degF max.
libellav15
Totally agree re the RPM - its actually more like 650rpm so no probs there.
900 rpm is pretty much the max revs we ever get to on the river (4mph limit over here) unless anyone isn't looking :D
Idle was the wrong word to use - just wanted to know the amount of flow we should be getting when pottering along at 4mph.
I am quite re-assured that no-one has panicked or been alarmed about the riser being quite hot to touch.
So....the plan - as a result of your guys input:-
1) Check flow into bucket both before and after thermostat - to confirm circulating pump is also good.
2) Splice in a bit of clear pipe before t/stat - obviously if the flow is good through the pipe it will confirm the circ pump is also good.
3) Get a second temp gauge with numbers on.
Cheers guys - as usual - fantastic.
Adam
myoldboat2
Adam, I think this article will be of interest to you, especially the section on Raw Water Pumps (red highlights mine):
Cooling Systems Tips
**WARNING - Make certain that the fresh water cooling system is not hot before removing the pressure cap. These systems normally operate with hot fluid under pressure. Injuries can result in carelessly removing the cap of a hot system**
FRESH WATER COOLING SYSTEMS - GENERAL TROUBLE SHOOTING
Temperature Problems
1. Before spending too much time chasing a temperature related problem, make certain the gauge is functioning properly by checking the gauge against a known good thermometer. Many inboard & I/O marine temperature sending units are the same basic devices produced for automotive applications. Since automotive engines normally operate at temperatures higher than marine engines, these devices can sometimes provide inaccurate readings.
2. Normal marine fresh water cooling systems allow the engine to operate at temperatures moderately above 160 degrees F. However, as the heat exchanger accumulates time the system may begin to operate in the range of 170 degrees F. NOTE - In most marine cooling systems a normally functioning system should never allow the engine to operate at temperatures in excess of 180 degrees F.
Thermostats
1. Marine engines utilize special thermostats specifically design to function in fresh water cooling systems. Although many people replace their marine thermostat with automotive replacements, in many cases they are subjecting their engine to conditions which will cause long term damage. In many cases this damage will not show up for a period of time, and do so in ways that appear unrelated to the cooling system.
2. Overcooling - Since the fresh water cooling system generally utilizes a heat exchanger designed for a particular application, the heat exchanger has been designed with a certain amount of capacity. This includes excess capacity to account for normal system degradation. Therefore, it is generally simple to identify overcooling related problems. These types of problems will almost always be thermostat related, usually an improper thermostat being used or something lodged in the thermostat and not allowing it to close properly.
3. Overheating - These types of problems can be more difficult to identify but in many cases related to a malfunctioning thermostat. Verify that the thermostat functions properly by inserting the thermostat into a pot of boiling water. Most thermostats will have the opening temperature stamped somewhere on the part, and should reach full stroke at approximately 20 degrees above the opening temperature. Thermostats are not repairable and should be replaced with the manufacturers specified part as these are system specific components.
Raw Water Pumps
1. Most fresh water cooling systems are designed with raw water pumps that provide approximately 30 - 35 gallons per minute (gpm) of water flow. Therefore, for a full fresh water cooling system (including the engine heat load as well as the exhaust system) the general temperature rise for the raw water will be approximately 50 degrees F. This means that if you were operating in 80 degree F water conditions, the water temperature exiting the heat exchanger and entering the exhaust risers should be in the range of 130 degrees F. The normal temperature tolerable to the touch is 140 degrees F. Therefore, if the proper amount of raw water is being delivered, the exhaust risers should feel hot to the touch, but tolerable.
2. Most sea water pumps used today utilize a flexible rubber impeller. While these types of impellers do a very good job at producing flow while tolerating a certain amount of debris, they are extremely susceptible to heat related dry run failures. While the Mercruiser style composite bodied water pump was very good at resisting corrosion, it lacked much in dry run capacity. This is due to the fact that composite materials do not dissipate heat nearly as well as metallic materials. To be on the safe side, an impeller should be changed at least every other season if not every season.
Heat Exchangers
1. For most marine applications the tube and shell type of heat exchanger is used. However, larger commercial application will sometimes use a plate heat exchanger, but these are generally more expensive and very difficult to service.
2. In a tube & shell heat exchanger the raw water passes through the inside of the tubes, while the ethylene glycol passes on the outside of the tubes. Most generally the raw water side of the unit will allow for several water passes as increasing water velocities also increases heat transfer efficiencies. The glycol portion sometimes referred to as the shell side, generally allows for a single pass but has baffles to force the coolant flow upwards and downwards in an effort to also increase heat transfer.
3. One of the difficulties facing the marine cooling system, or any cooling system for that matter is in separating the air from the coolant. Air is a very poor conductor of temperature and therefore will force a cooling system to overheat almost immediately if a significant amount is contained within the fluid. Most original equipment heat exchangers now utilize a separation chamber to allow for the air to be separated from the fluid and then purged to the overflow bottle. Some marine engine manufacturers, and most automotive manufacturers now utilize a pressurized system which separates the air from the fluid and retains it in a structural designed reservoir. The main advantage of this design is the ability to service the system and allow for the highest level of system efficiency since it will constantly separate air from the fluid, not just when the engine is shut down and cooled (thermal-cycled).
http://www.perfprotech.com/store/articles/cooling-system-tips.aspx
libellav15
cheers myoldboat - fantastic info.
35 gpm though - blimey - thats like a gallon every 2 seconds!!
i pulled a pipe off the thermostat housing today - and noticed the inside was fairly corroded but flow looked ok - NOT a gallon every 2 seconds though :)
what rpm would it need to be at to get that pump rate - WOT?
The bit abut the riser temp should be hot but tolerable is great too buddy cheers.
What are the symptoms of running too hot? would it be / could it be misfiring/bogging etc etc?
i am having timing issues as well - runs well for half an hour then starts missing/hesitating etc - perhaps the symptoms could be linked.
cheers bud
adam
