mercriuser 3.0 frozen ?
tnash542
I have a 95 motor the starter went bad , engine been sitting a while is there a way to turn the engine over ? there is no way that i can see since the motor doesnt have anything to to put a socket on and the motor backet is in the way. dont want to buy start if motor is froze. thanks todd
Alumarine
Re: mercriuser 3.0 frozen ?
You should be able to put a socket on the alternator bolt and turn it over that.
You might have to put extra tension on the belt with your hand.
CheapboatKev
Just have to toss out there that the plugs are removed right?
Also, I have used a oil filter wrench (the belt/strap type) to do this also.
Ayuh,... Is the Starter Out,..?? Use a prybar on the ring gear...
