superwooter
Thread starter- Joined
- Oct 12, 2009
- 167
well i was going to start off by posting a picture file of the mercontrol diagram but photobucket downsized it too small to see anything. so instead, here's a link to another thread that has a good quality copy attached. its about 12 posts down....
http://forums.iboats.com/showthread.php?t=120947&highlight=MERCONTROL+DIAGRAM
my problem is with part numbers 13-16 which are:
13-detent pin
14-detent pin spring
15-detent pin tension spring
16-welch plug
a few days ago while fishing, i raised the throttle arm and i heard a spring vibrate. i tried to lower the throttle arm and it would not set all the way back down. i raised it back up to see what the obstruction was when i noticed that a spring was sticking out the back of the MerControl housing! i had to hold the spring in with a knife blade in order to be able to lower the throttle arm. so now the throttle arm is all that is holding the spring in. i guess the housing must have become weak and given out behind the spring.
has anyone experienced this before, and does anyone have any idea how to go about fixing it? also, what does this spring do? will it cause problems if i simply remove the spring?
thanks,
superwooter
13-detent pin
16-welch plug
thanks,
superwooter
