MainstreetUSA1
Thread starter- Joined
- Jun 12, 2004
- 49
I have a mid seventies (serial number starts with 410...) 20 HP merc shortshaft with a mercontrol remote control.<br /><br />The problem that I'm having is when you shift the control lever forward, the engine is placed into reverse and vice versa.<br /><br />The splines are lined up correctly on the lower unit because neutral is where it should be.<br /><br />The throttle is working fine its just the shift lever positions are swapped. This is why I think the problem lies within the mercontrol unit.<br /><br />The one thing i noticed is that on the shift linkage on the engine, the barrel on the shift linkage does the actual moving and the eyelet on the end of the shift cable is held stationary. On the throttle side its the opposite. The barrel is held stationary and the eyelet on the end of the throttle cable does the moving. Is there some way to open up the mercontrol control box and change the way the cable moves with respect to the control lever postion, to accomodate this motor?<br /><br />I would like to get it set up so when you push the lever forward the boat goes forward!<br /><br />Thanks For Your Help!!!
