yamahadude9
- Jun 7, 2010
- 25
Hello im in the process of rebuilding my carb on my 1987 165 3.7l 4cyl and its the original mercarb. It has the accelerator pump with the 90 degree bend on the end of it, is there supposed to be a check ball under the accelerator pump on this one ?? i see something that looks like a little ball from the outside ( see attached pic) i pressed in on it a little and it didnt wanna budge ?
also is there some sorta trick to removing the little tee and spring under the venturi and is there a check ball under that one ?
