12Footer
- Mar 25, 2001
- 8,217
This one is a long one, but I am totally buffaloed! This engine is a 1988 Merc 15HP. The complaint was great startup, great idle, but very poor operation in gear, with any throttle. It came to me with a classic <br />fuel-starvation problem,which turned out to be debris in the check reeds of the fuel <br />pump(integral to the carb).<br />I removed the carb, ordered the kit (36 bukz!!), and rebuilt it. I re-installed the carb,but found a missplaced timing linkage rod from a previous repair.See, the reason I got this boat to work on was my big mouth. The owner spent 500 dollars thru a wrench,who<br />replaced the coils and trigger. He charged waaay too much, and the engine ran no better than when the owner left it with him.<br />I took the cover off this engine, and noticed the rod thing right off, so I told the owner I would check the guy's werk, and find out why it continued to run poorly underway.<br />So anyhoo, I mounted the carb, cranked the motor thru,and it started first pull, but SMOKE. I mean this thing was kicking thick <br />blue smoke like the choke was on! The idle mixture screw seems to have no effect.This would tell me the choke is stuck closed,but this thing HAS no choke plate,but a "mixing<br />chamber". I'm not sure how this mixing chamber - choke arangement werks. Can anyone describe the thing to me?? The exploded view and associated literature DOES NOT (Clymer manual), and I have no clue. The choke knob has to be removed to get the carb off,and I'm thinking I installed the knob cam or something wrong. Outside of this, I figured the timing was way off, due to the linkage being installed wrong initially, and possably set to compensate. It was off,but not by much, and I brought it into spec.Still won't idle,and too much fuel!<br />I'm about throw a tarp over this thing,and let it sit there for a year or so
<br />Any insight would be greatly appreciated,as to what could be wrong,and just how this screwie @#$& choke system operates.<br />It's enough to drive me to drinkin, this merc<br />with the problem of blue smoke stinkin!!<br />
