Merc115 EFI Shaking?
mjp
I have a Merc Fourstroke EFI 115hp. Model #1115F13ZD. Went to go for a ride today and it shakes like crazy. Also has a loss of power. It wont go very fast at wot. I took off the fuel pump and its clean inside. Also has a vacume. I tested it with a guage. Its fresh gas in it also. I took the fuel filter apart and that was clean also. I dont think it a fuel issue. Its almost like maybe its running on three cylinders? Anyone have any idea as to what I can check next? Or should I just call a mechanic.
Thanks,
Mike
fedpo
Re: Merc115 EFI Shaking?
Did you ever get this problem diagnosed? I am having similar issue with 2003 200 HP Mercury, 2 stroke.
mjp
I have not. I am going to the marina to see if I can have a tech look at it. I have done all I can. I think its some kind of sensor. Good Luck,
Mike
shadowcrest5
I too have this same motor. It runs great in driveway. Yet....under load on the lake...it has very little power. And it continues to shake as I attempt to throttle up. At best I can get about 3200 rpm wot. What year is your motor. I have a 2005. I have a post on here about it....Sep 24th." where is my power..fuel restricted ?".
If you find out what the problem may be ...I'd appreciate any info.Good luck. We are going to need it!!!! Thanks Shadowcrest5......
mjp
Mine is a 2002. Sounds exactlly what my issue is.
Mike
