Merc wont run
Private Nemo
Hi, I have a 1985 Mercruiser 260. When I start it , it starts right up, but dies. As if someone turns a switch off. It runs for maybe 10 seconds , give a take.. Motor sounds good, just wont stay running. Any thoughts are appreciated.
thanks
Drew
dubs283
Re: Merc wont run
have you inspected anything?? fuel/spark??
does it run longer if you increase throttle?? pump throttle??
does it fire right back up once it dies??
Private Nemo
Re: Merc wont run
Hi,
Yes , I inspected everything before I fire it up. It looks good. Does not run longer at higher rpms. Any speed , just cuts out. Yes, it starts right back up.
thanks
Drew
dubs283
Re: Merc wont run
i would start by checking the fuel supply, make sure the carb has fuel in it
one check is to see if the accelerator pump squirts fuel after it dies
when it does die, have a helper pump the throttle while you look down the carb, you should see two definite squirts of fuel, one down each barrel
are you pumping the throttle before starting the engine??
Private Nemo
Re: Merc wont run
Dont have a helper handy, but I discounnected the throttle linkage and check for squirt. Two perfect squirts. When the engine is running for example at 2000 rpms, I watch the tach just die, like power was killed.
dubs283
Re: Merc wont run
try running it with the tach disconnected, negative side of the coil
is this a t-bolt ignition??
NHGuy
Re: Merc wont run
That's a wiring or ignition fault, find the manual & troubleshoot it unless someone on here already knows the steps.
achris
More fish than mountain goat
Re: Merc wont run
If it has points, that sounds like the resistance wire is open circuit.
Private Nemo
Re: Merc wont run
Hi, Thanks for the replys. Yes this is a T Bolt ignition. I am not sure what eliminating the tach will show , but I will try it later today. I will give anything a try right now .
thanks
Drew
Don S
Re: Merc wont run
If the tach is shorted internally, it will short the ignition to ground.
Here is the troubleshooting chart for the Thunderbolt IV ignition.
You might want to check the purple wire on the coil while someone starts the engine for you. You may be loosing power due to a defective ignition switch or a bad connection, or the lanyard safety switch is either off or defective.
Private Nemo
Re: Merc wont run
I was able to put some time into troubleshooting this problem. What I did is disconnect the tach. The engine ran about 30 sec vrs. 10sec. But still cuts out abrutly . I even switch the module, from inside the distributor, from this engine to the other and vis a versa, made no difference. Either module , same results.
thanks
Drew
Private Nemo
Re: Merc wont run
OK, So I was able to put some time into this motor. So far , I have disconnected the tach , swap out the coil, swap out module inside dist, swap out dist computer. The little black box, that connects to coil and dist. Absolutely no difference. I would REALLY appreciate any advice.
thanks
Drew.
Don S
Re: Merc wont run
This engine hasn't been converted to an electric fuel pump has it?
riptorn
Re: Merc wont run
I am not sure about this type of motor but is there a primary pick up coil in the distributor? I think one end plugs into the module.
Private Nemo
Re: Merc wont run
Not sure what you mean, . There is a module inside dist, with two small studs for wires to go on , outside of the dist cap.
achris
Re: Merc wont run
You need to verify that you are in fact losing spark. Put a timing light on a spark lead and check that you lose spark as the engine spins down.
Chris..
riptorn
Re: Merc wont run
Do you have pictures of the dist cap and the module and cam (rotor sits on the cam).
Pete104
Re: Merc wont run
Disconnect the engine harness & try hot-wiring it! The original sensor could cause this, especially if it has bad ground.
Even at that, can you keep it running by nursing it?
