Re: merc shifter
The engine should be running to be able to adjust the linkage.The reason for this is the driveshaft must throw one gear out,and the other in. You can sometimes "luck-out", and get to shift, but you really can't adjust the linkage properly.<br />Did you drain the lower unit?<br />If not, do so. Get an oil pan or 1lb coffee can,and remove the "vent" and "Fill" screws.<br />The lube should be translucent green, not milky or grey, which would indicate a bad seal.<br />Either way, run your finger thru the lube,and feel for chunks of metal. If you find any, the problem is the forward gear has been damaged.
