MERC Question For all the Merc Specialist!
Hitman65
I am working on a 2000 Merc 200 Saltwater Carberated. I have two problems I cant figure out the first is how does the lower unit produce the pressure for the speedo pickup? The reason i ask is it doesnt produce any water pressure until the boat is going what I would guess about 15 knots.<br /><br />Second question is much tougher. we took it out bumped the throttle up to 2000 rpm I am at the motor (hanging over the transom) watching the linkage to see if i have a hanging cable. Anyway it stablizes at 2000 and sets there for about 5-10 seconds and then auto accelerates to 4000 rpm in a smooth sweep. At 4000 it stablizes and cruises there with no problem. The real problem is if you want to set the throttle at lets say 2800 to cruise along it wont do it. It will go directly to 4000 rpm or so everytime. At 4000 as I said it will stabilize and is fine. if you try to bump it up to say 4500 it accelerates to 6000 and is fine there. There is no surging in the motor and it runs fine at the setting you can set it at but at idle and 1000-2000 rpm it runs a little rough. Nothing more than a normal motor under break in conditions. This motor has about 5 hours on it. Any input would be appericated.<br /><br />Hitman
Hitman65
Re: MERC Question For all the Merc Specialist!
Can anyone help me on this one????
Walter
Is this motor still on warranty? If so, I wouldn't hesitate to take it my Merc rep and say..."Let's go for a boat ride!!".<br /><br />Walt
Hitman65
I am the Merc dealer Walt.<br /><br />I have read all the manuals and found nothing!
clanton
IS it rigged per Merc installation instruction. if so I would look at all linkage for correct adjustment and smooth operation,fuel flow with clear hose for air leak. I just did 2001 200hp<br />ran great out of the box.
Walter
Oops...I thought I was talking to the owner. As far as the RPM changes...I wish I could help ya...but I have never seen a 2000 Merc let alone worked on one. But as far as your first question...I guess I'm not quite understanding what you mean by the lower unit "producing" pressure for the speedo. I always believed only the force of the water against the lower unit as the engine moves through the water creates the pressure against the speedo pickup which is calibrated & read at the speedo head. I know my speedo doesn't read accurately at lower speeds either...
manowar
take it back sounds like throttle and or linkage adjustment problems
hondon
Even though this is a carb V6 ,you still have a throttle position sensor .Why are'nt you calling merc tech for help?
clanton
DO you have Merc service manual? My manual stops at 1999. Look in chapter 2 electrial page 2A19/20 low speed/highspeed advance module and idle stabilzer module, may be the problem.
hondon
Also if this thing has added SMARTCRAFT gauges and they have not been wired to spec this can cause the ECM to do alot of wacky stuff.
clanton
When you get merc running, I would like to know what problem was?
clanton
Walter
I've gotta go back to my first posting, which has now been verified by Hondon....<br /><br />There's a lot of folks in this column who are "in the know". Yet, I just gotta say this... If I were you...I wouldn't even hesitate to be knocking on...no, scratch that...KICKING DOWN Mercury's door screaming... "HEY, WHAT'S THE DEAL WITH THIS THING??? SHE RUNS LIKE CRAP AND ONLY HAS 5 HOURS ON HER!! TOSS ME A FRICKIN' BONE HERE, WILL YA PLEASE???? BY THE WAY, WHERE'S CARL WHEN I NEED HIM??"<br /><br />Anyway, that's what I'd do...<br /><br />Walt
hondon
HELLO?HITMAN?
clanton
MR. Hitman65 would you please keep us posted on How goes it with the engine.
clanton
hondon
Just trying to keep you on the fist page. PLEASE respond. Are you allright?
12Footer
I've been keeping silent on this one,as I am no Merc expert by a long shot...But I'm juyst wondering what the mod#/ser# are.
