merc outboard
packagedeal
I mixed about a qt of gear lube oil by mistake in my oil resv of my merc 200 hp offshore engine. will this hurt?
CharlieB
Re: merc outboard
You have a potential for disaster if you do not drain it, clean it, and start over.
1. Gear lube will not flow as freely as TCW-3, the motor will not lube correctly and toast bearings and cyl's.
2. Gear lube will not burn like TCW-3, if you are lucky, it will foul spark plugs and die before it scours the bearings and cyl's.
Are you willing to take these risks and run it?
I don't think so!
packagedeal
Re: merc outboard
thx. the resv. holds 2 gals of oil to mix with gas. fuel injected. i only poured about a qt.
Moody Blue
Re: merc outboard
OK, motor worth maybe $13K, and you have about $40 worth of oil that is now mixed with something that is not supposed to be in there. Your motor, your choice :)
No way would I risk it.
CharlieB
Re: merc outboard
If you are as cheap, Oooops, I mean, as cost effective as I am, then save the oil in a separate container and use it to mix for weed-wacker fuel.
But like I previously posted, it WILL toast your motor, not IF, but when. When that gear oil restricts the flow of TCW-3 you WILL lose that nice $$$$ motor.
Always remember that old adage.
Pay a bit NOW, or pay a whole LOT later.
Which can you afford?
It isn't even worth thinking about, is it?
Just change it and be done.
And I bet you will NEVER make this mistake again, so actually, it is a cheap, errr, I mean, a much more cost effective lesson than a whole motor.
