Merc. Outboard 25hp lower end
Gewe
I have a 1981 Merc. 25hp outboard and I'm working on the lower end. The problem I have is the reverse lock was taken off before I could see it's position and know I've been trying several positions to get in the right place. The problem is the engine is very hard to get into reverse. What position does the raised portion of the reverse lock go in when in neutral?
corm
Re: Merc. Outboard 25hp lower end
Hi Gewe,<br />Not real sure what the raised portion is and<br />am at home not work. The reverse lock holds the motor down in neutral as well as reverse<br />so set it up for that usage.Also the problem<br />could be in the wires inside the handle.<br />Hard to tell with out knowing what you fixed<br />or took apart. Hope this helps.
<br />...have fun...corm
2dbit
http://www.crowleymarine.com/mercury-outboard/parts/676_12.cfm
It may be difficult to understand based on the breakdown I've provided, but when you compare the parts in the picture to your motor, it may become clearer.
I am actually working on a 1983 18hp merc that just had a run-in with a rock at WOT effectively bending the propshaft. (hooray. the aluminum prop survived...) I digress.
One of the problems I discovered while inspecting this persons motor after the accident is that when in forward, the shift lock was still engaged(explaining why when they hit the rock, the motor was only holding on by one clamp) The way I fixed this is by bending the top of part #7 (ref. diagram) down. By tweaking the angle of this arm you can alter when the lock arm is raised. (now it's locked in neutral and reverse but releases in forward)
It is a little difficult to understand completely your question but if you need a picture of the arm's installation on my motor, just give me a heads up.
