Just found this site and I'm confident with all of the knowledge out there someone might have an answer or solution. Last year I hit a rock in shallow water at full throttle. I did some lower unit damage and had it replaced by a Merc dealership. Now comes the problem. If the motor is running at med. to high revs no alarm. If I idle down to it's lowest rpm's my heat alarm will sound off. I took the motor back to the place that did the work and they informed me that my pump was fine, couldn't find any problem with the module as well. I never had any problem before it went to the shop. I'm pulling my hair out. With any luck the Kenai will open up for king fishing in July and I would like to have a motor that doesn't wake the dead if it idles to low. Mechanic told me after the last go around that he was certain that no harm is being done to the motor, just a gremlin so to speak. Should I just disconnect the alarm wire? Thanx for all of the help in advance<br /><br /> AK Jack
