My buddy's boat engine has problems. It is a 1994-96 (?) Mercury tracker, 115 hp. It starts (with push-to-prime key switch) and runs for a bit, then slowly idles down til it dies. Pushing the primer keeps it going and revs the engine. Same if squeezing the primer bulb on the fuel hose.
The gas is fresh. Switching to another tank, same result.
The fuel filter is clear (blew thru it, no resistance).
The fuel pump seemed fine (check valves worked, no holes in diaphragm) but we rebuilt it as the diaphragms were stretched. No change.
Just for kicks, I changed the plugs out for new ones. No change.
We can keep the engine running using either the primer bulb on the fuel hose, or the push-to-prime key switch.
The boat sat out last year out of the water. We really don't feel comfortable taking it out for a full throttle run as it is now on the Mississippi and has no back-up engine.
I am a mechanic, and am familar with 2-strokes, but have never worked on a boat motor before. I am fairly certain it is a fuel issue, and the motor seems to be carburated. No fuel leaks are apparent, the primer bulb (on the main inlet fuel hose) stays hard and we have switched tanks & hoses (2 removable tanks) with no change. It runs good when started (& primed) then slowly runs out of fuel. Lifting the prop out of the water and engaging the transmission only allows the engine to spin at about 2,000 rpm. Squeezing the primer bulb or pushing the primer in makes it rev to 5,000 and sounding right.
Any advice would be most appreciated.
