Re: merc distributor troubles
It cannot move at all. It it turns by hand (carefull not to break it tho), then this is the problem. The timing belt may also have jumped a tooth.<br />To check this, remove the plug from #1 cylinder, and put a breaker bar on the flyweel nut. insert a pencil into the plug hole a ways, and rotate the flywheel clockwise, until the piston is at top dead center (the farthest out that the pencil gets). After finding TDC, you should find the rotor on #1 plug terminal on the dist cap, or very close to it. Close does count here.If it is in between #1 and another one, or not even close to #1, your dist jumped time somehow. The only question remaining is
what component let go?<br />The areas this can happen in are.<br />Flywheel key (sheared out,,somewhat common)<br />timing belt broken or tooth jumped on pulley(not common at all).<br /><br />Rotor stripped out at the dist shaft (most common)<br /><br />plug wires transposed when changing plugs or testing (but yours went off underway,so that's out).<br />The pencil shoul at least let you know if timing is an issue or not.<br />If not, we are back to the drawing board...With a greasy pencil,I might add.
