Merc Carb Winterizing
Dave_K
Hi All,
I have a 1992 Mercury 40 Horse 2 stroke outboard. Serial# 0d173870, Model# 1040411MD. I garage it over winter and in spring it won't start without a good carb cleaning. What do you guys recommend for winterizing ? I can drain the fuel bowls with little trouble...
Chris1956
Honorary Supreme Mariner
Use some fuel stabilizer in the fuel and run the motor on that mixture a few minutes. You can drain the carb if you like.
On my V6 with three 2 bbl carbs, I just stabilize the fuel and leave the carbs full.
airshot
Hi All,
I have the same outboard, owned it for 5 years. Always keep my fuel stabilized. At seasons end, I drain my built-in 18 gallon tank and use that fuel in my winter toys. In the spring I use fresh fuel with stabilizer in it and it always fires right up. Original owner did the same thing, so I just followed that lead. One other thing I mention often....watch where you buy your fuel ! Every so often run a fuel test to be sure your not buying crud to begin with. In many cases, the fuel people buy is already contaminated.
Do you have an inline fuel filter?
Mc Tool
yep drain the fuel ....if its not there it cant cause problems . One of my friends fills his float bowls with kerosine for the winter as it doesnt deteriorate.
He migt be on to something as my kerosine lamps will fire up straight away after sitting for years . Obviously on a gas motor you'd have to drain the kero and prime as usual with fuel .
