Merc Carb Winterizing
Dave_K
Hi All,
I have a 1992 Mercury 40 Horse 2 stroke outboard. Serial# 0d173870, Model# 1040411MD. I garage it over winter and in spring it won't start without a good carb cleaning. What do you guys recommend for winterizing ? I can drain the fuel bowls with little trouble...
Use some fuel stabilizer in the fuel and run the motor on that mixture a few minutes. You can drain the carb if you like.
On my V6 with three 2 bbl carbs, I just stabilize the fuel and leave the carbs full.
airshot
Hi All,
I have the same outboard, owned it for 5 years. Always keep my fuel stabilized. At seasons end, I drain my built-in 18 gallon tank and use that fuel in my winter toys. In the spring I use fresh fuel with stabilizer in it and it always fires right up. Original owner did the same thing, so I just followed that lead. One other thing I mention often....watch where you buy your fuel ! Every so often run a fuel test to be sure your not buying crud to begin with. In many cases, the fuel people buy is already contaminated.
Do you have an inline fuel filter?
