ah64aviator
- May 9, 2010
- 37
Re: Merc audio warning system not working and engine won't crank
Oh ok on the S104. I used the grounding block that is mounted above my battery on the left rear side of the boat and went from there to pin D of the relay, which is terminal 28 is it not? I hope I'm reading you right.
It's a soldered together bunch of wires all wrapped up.
Use an OHM meter. One lead in the terminal of 28 and the other on the ground stud on the back of the engine.
