weeksender
- Jul 23, 2009
- 5
Hope someone can figure out what could be causing my engine to suddenly cutout. I have been working on this engine all summer, and I still haven't had a boat ride lasting longer than 15 minutes. Summer is over, I'm nearly broke and I'm tired of paddling back to the boat launch.
Engine starts OK. However, after it warms up or runs for a few minutes it suddenly cuts out (no sputtering, smoking, nothing). It's like someone turns the key off. This may occur at full throttle or at idle. When this first happens, the motor restarts with no trouble. However, it then gets progressively worse over a course of a few minutes (where it runs shorter intervals before cutting out, and gets harder to restart).
So far, I've cleaned and rebuilt the carburetors (with new floats, gaskets and needles). I've rebuilt the fuel pump. Replaced the water pump. I've replaced ALL the hoses. Replaced the external and internal wiring harnesses. Replaced the ignition switch. Replaced the gas tank with all a new hose and fittings. Changed the gas in the tank. Although, overall, the motor runs smoother, it continues to cutout as before.
Any thoughts??? I don't know where to go from here, except to the boat dealer to trade "the Money Pit" in this spring.
Thanks for any help,
weeksender
weeksender
