Merc 90 late 80s vintage - prop seal advice
CharlieZulu
Lower unit oil has water in it, so time to have a look. First time I've tried. See pix.... Is this O ring all that keeps water and oil apart???IMG_00000638.jpgIMG_00000637.jpg
Laddies
Banned
Re: Merc 90 late 80s vintage - prop seal advice
There are 2 seals on the prop shaft, 2 under the water pump and 1 on the shift shaft. the last 3 require the unit to be remove from the mid section to be changed.
CharlieZulu
You can see the O ring in my pic..... Where is the 2nd seal located? Maybe mine is missing??
Laddies
Banned
Pull the prop shaft out of the carrier and you will see the 2 seals 1 goes in and the other out.
CharlieZulu
I have the shaft out..... where are these mysterious seals?? See pic.
CharlieZulu
Thanks folks, so far so goodthis is my first time. So how do I get all the guts out of the Carrier Assembly I can see the messed up seal:
Laddies
Banned
Reach thru the prop shaft bearing with a long punch and drive the seals out, by tapping on one side and then the other to keep the seals from binding
M
Maxz695
Guest
on the front of the carrier
Charlie, There are also seals in the base of the waterpump for the driveshaft and around the shif shaft. These are a lot easier to change than the propshaft seals.
CharlieZulu
Holy cow I am finding this tough....I put a large flatwasher down in there and have been pounding on it with a large punch and nothing seems to be moving. are all the components inside the carrier removeable? Am I whacking on the right thing?
The other end:
CharlieZulu
In other words, can the two rubber seals be replaced without tearing all the guts out?
