Merc 888, Prestolite to Oildyne tilt/trim pump
Dave_A
A leak in the tilt/trim and a non-functional reverse-lockout have prompted me to replace my tilt/trim pump.
I got an 'Oildyne' type pump (SAE J1711 or something like that) from Ebay, which has 4 hoses coming off of it (it has 2 connections on the front, which then each have a brass 'block' that allows 2 hoses to hook up to each 'side' of the new-style pump).
From what I've read here, to do the switch, you hook 2 hoses up, one from each side of the pump, directly to the outdrive.
So, why do I have 4? Was this pump from a twin-outdrive boat, or do I have the wrong pump, or what?
Bt Doctur
Re: Merc 888, Prestolite to Oildyne tilt/trim pump
Post a pic of what you got. Pumps have 1 up and 1 down line. Even twins have their own system
Don S
Sounds like you may have found an old Mercury outboard trim pump. As I recall, they have 4 lines going to them.
JustJason
sounds to me like an old pump to, the old ones with a seperate reverse lock.
Dave_A
I'm replacing the separate reverse-lock, prestolite type (with the black metal res. on the bottom, that you fill through the screw-hole.
Don't have a digicam, but the new pump LOOKS like the new type (plastic tank, yellow cap, says 'SAE J1711' on the plastic motor housing) - it just had 4 lines hooked up to it.
The 4 lines went (2 each) into 2 brass 2-into-1 fittings, that then went into the pump.
I'm thinking I can replace those 2-into-1s with regular 1-1 fittings, and then I should be able to use it - unless this one (like the one it's replacing) requires a reverse-lock....
REPLACING:
WITH A PUMP THAT LOOKS LIKE:
But had 4 hoses hooked up to it, 2 to each 'side' of the pump....
Dave_A
From all appearances, the 'Up' and 'Down' ports have 'F' fittings (think 'T' fitting, but both 'outs' on the same side, 90 degrees from the 'in') attached. 2 identical hoses are hooked up to each 'F' fitting.
I am thinking of just replacing the 'F' fittings with 'L' fittings, and going with that...
