FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1956 mercury 850, runs good,but shows no water venting out. Does this model vent water underwater? I've seen no hole for the water to come out. Motor doesn't get hot, I can remove outer shields and hold my hand against engine.
Sorry, typo it's a 1965 mercury six 850 85hp kiekhofer, serial#1650244,dual distributor, points, what-not, found out today she has low compression, water in lower unit timimg and idle is off. repairs will cost more than she is worth. hard to find parts for,tuning her is a real chore any suggestions?
Ok guess I'll ask.
In your first post, you said it runs good. I assume your having doubts about the waterpump. My guess is you bought it to a shop. They tell you all is "not good":.It will cost you "this much", but we'll sell you a new one.
First off compression is more about being equal, than meeting the "orginal"
values. If your cylinders read within 10Lbs of each other, and are not much less than say 80% of new values, then it should be fine. As for the timing being off, the link and sync is relatively easy for these motors, if your a bit mechanically inclinded, and can follow it step by step. Water in the lower unit is also an easy fix, unless you ran it full throttle over some rocks since you have owned it. somehow i don't think you did.
You might want to consider doing a "seafoam" and "Deep creep" treatment to the motor. Sometimes, on older motors the rings get stuck up (Newer motors too). These two products really work, and will deffinatly make an improvement in motor perfomance. If you do a search on the forum, using the word "Seafoam", you will find out the how and why's of it.
