Merc 850 Flywheel
hulteen
I have a 1974 Mercury 850 4-cyl with the "Thunderbolt" ignition<br />I took apart my flywheel to get to the stator, mistake #1, I didn't mark the flywheel and the hub, mistake #2, I need to replace the belt to the distributor while I have it off. I need to know how to re-align the flywheel so i can bolt it back to the hub, the only distinctive markings on it are 3 dots no stickers, of marks other than that. Once I have the flywheel re-aligned to the hub, and the 8 bolts replaced I need to set the timing, I just bought this boat, it is my first, It's a fixer-upper, and money is tight, any help on this would be greatly appriciated, I cannot afford to take it to a professional, and I'm quite adept at work on automobiles so this isn't completely new stuff to me, and please don't tell me to buy a book quite yet, I looked at 2 seperated service manuals on this motor and they are too vague on this issue, anyway, thanks for any help in advance. <br />--------------------------------------------------------------------------------
steve forsythe
Re: Merc 850 Flywheel
Whats up with posting 3 different topic names with the same question?? :confused:
JB
Really bad forum manners, NeedMercHelp.<br /><br />Get a manual.<br /><br />Good luck. :)
hulteen
well, on the subject of forum manners, I posted this same message 3 weeks ago and received no reply, nothing, I bought a manual since and it is still kinda confusing, I was hoping maybe somebody could help, the intent was not to annoy, merely to get noticed, but I can see I received only criticism, and my am no closer to achieving my goal of repairing my outboard, so I really haven't lost anything, considering no one was going to help anyway, and this was proven by the fact that no one gave a legit response to this post.
hulteen
Does anybody ever answer questions on here, maybe try to help someone out, or do you guys just criticise each other while your boats stay broken?
The_FoX
Where in Alabama are you from Needmerchelp? I live in Huntsville and I could help you if you lived near. I have a Merc 800 so alot of the stuff will be the same.
JB
NeedMercHelp.<br /><br />If you don't get any response here, it means that nobody understands your problem well enough to be any help.<br /><br />Being impatient and rude reduces the likelyhood that you will get anything but rude replys.<br /><br />I suggest that you edit your post to make it more clear what your question is. <br /><br />I am not a Merc-spert and I am mystified by your description of your trouble. There are Merc masters here. If they can't help you you are beyond help.<br /><br />Good luck. :)
