Re: merc 850 1977 no fire but passed the switchbox test
i will do that ..at this point i l try anything ..
but dont put to much hope in it cause if i recall when i manualy aim the rotor to a plug wire , disconnect de distrib wires ..put the cap back on and jumped the 2 connector on the switchbox to smimulate the trigger s job i was getting a spark on the plug..
but i will redo this test i im not sure of anything anumore ...i ve tested every thing so many times.. but aparently this test is not exactly as cranking with the starter cause teh switchbox may not have a minimum of 9.5v while the starter is cranking it ...
thanks for the info i will try it any way... and if it works ...i will bang my head on a wall for an hour.
JT
